Some misfire on boost
Post by Vlade »
Well the car was running so great... but you know being an SX it have to let you know every now and than that its still an SX
I've got a misfire intermittently on boost, initially I thought it was because the car is cold... now it happened when the car at operating temp. It sounds like I'm hitting the limiter when the car comes into boost, and that is not gunning it about 50% / 70% throttle...
Haven't checked anything, will check plugs and coils tomorrow afternoon, got a slight suspicion its the fuel pump.
Any ideas what it can be?
widowmaker
Real Name: Walter
Post by widowmaker »
actuator circlip?
Plugs.
Fuel Pump, check the pipes in the tank as well.
Sokar
1.0 Bar Boost
Post by Sokar »
Check compression in cyl 3, oh wait, its not an SR20 :P
Captain Slow to the rescue!
Post by Vlade »
haha...
No the misfire seems to be across all cylinders, like I said it sounds like I'm hitting the limiter when the boost comes in...
PLUGS!!!
What is your charge and discharge time??
that depends on how old you are...
as you age your charge time takes way longer while your discharge time happens very quickly! :lol: :lol: :lol:
Slide 'em Wide
0.6 Bar Boost
Post by Slide 'em Wide »
:lol: :lol: :lol:
What Id rather be dooing!
n1smo200sx
Post by n1smo200sx »
plugs or CAS
Toby
Club Founder
Real Name: Toby Kurien
Post by Toby »
I think you neglected to mention the backfire. That suggests no spark or overfuelling. Maybe there's a problem with MAF sensor or the fuel map in your wolf ECU?
Post by Vlade »
Backfire? Did you see any backfires :D
Toby
Club Founder
Post by Toby »
Doesn't it make a loud bang as you get on boost at full throttle? Or is this now different to the problem you had during the Durban trip?
Slide 'em Wide
0.6 Bar Boost
Hey Vlade, Check your boost pipes from the turbo. If there is a leak then your motor is expecting more air and basically just over fuels and miss fires. I experienced it this weekend.
He runs a MAP sensor so this wont happen.
Have you checked the PLUGS??
