Powdercoat or Autostyle Caliper Paint?
Posted: Fri Aug 01, 2008 2:39 pm
by Doctor G
All my calipers are already sandblasted. Should I use the caliper paint they sell at autostyle or just powdercoat?
Only con of powdercoating is I have to remove the seals and pistons etc.
Anyone has experience with the caliper paint on a fresh sandblasted calipers?
Posted: Fri Aug 01, 2008 5:38 pm
i would say powdercoat cos you cant go wrong with the paint and potential heat damage!
but then you have to rebuild the calipers - if you dont have a rebuild kit, then it could turn out costly and time consuming!
so maybe the caliper paint is a better idea - less work. try get the spray type so that it comes out smooth.
my only experience with duplicolour paints is that they are really fantastic!!! top quality!
paint
Posted: Fri Aug 01, 2008 11:09 pm
by AR 200SX
just use base coat paint that you would normaly paint a car with,did a couple of cars and it works great,provided they are nice and clean.just use a paint brush with some benzine.
Posted: Fri Aug 01, 2008 11:17 pm
Posted: Sat Aug 02, 2008 12:41 am
by Ero_sennin
I used sprayon Engine enamel, and thus far its still perfect.
Posted: Sat Aug 02, 2008 12:37 pm
by Hotstuff
The only problem with the Duplicolor product, is that there is a time period that you are not allowed to use the calipers after being coated. According the can I have in front of me it says:"... wait 7 days for paint to cure..."
The finish is only as good as the preparation of the calipers to be painted. A well prepared rattlecan job can look just as styling as a powercoat or ceramic coat job.
Posted: Sat Aug 02, 2008 7:07 pm
by HancoB
Panit = Quick fix(Tried it, works great for a while, then you have to do is all over)
Powder Coating = Top quality(Much more expensive and looks great lasts long loads of work to get them nice)
In my case i'd use high heat paint and do a good job.
Posted: Sat Aug 02, 2008 7:10 pm
powdercoating = much more expensive???
what are you talking about?
powdercoating your calipers will only cost about 20 bucks more than a can of duplicolour caliper spray!??? and that includes sandblasting.
the more expensive bit comes in because you have to rebuild the calipers!
Posted: Sat Aug 02, 2008 7:16 pm
by HancoB
Oh FGS VC!
Thats the whole thing....
Powder Coating = more expensive.(with all the blah blah blah its still more expensive)
Paint = cheaper.
and BTW the paint costs you R50 a can and you can do all 4 calipers with 3 coats....Powder coating R20 a caliper=R80
mmm
Posted: Sat Aug 02, 2008 7:18 pm
powerkote is 600 per caliper!
Posted: Sat Aug 02, 2008 7:19 pm
by HancoB
Posted: Sat Aug 02, 2008 7:20 pm
just giving options.
Posted: Sat Aug 02, 2008 7:22 pm
by HancoB
So how much is it per caliper now???
20 bux more than a can of paint? or R600 a caliper?
Posted: Sat Aug 02, 2008 7:24 pm
powerkote and powdercoat are different yo...
go back and read the post again!
Posted: Sat Aug 02, 2008 7:26 pm
by HancoB
Soz I missed the K
Thats a K@K one!
