Powdercoat or Autostyle Caliper Paint?
All my calipers are already sandblasted. Should I use the caliper paint they sell at autostyle or just powdercoat?
Only con of powdercoating is I have to remove the seals and pistons etc.
Anyone has experience with the caliper paint on a fresh sandblasted calipers?
i would say powdercoat cos you cant go wrong with the paint and potential heat damage!
but then you have to rebuild the calipers - if you dont have a rebuild kit, then it could turn out costly and time consuming!
so maybe the caliper paint is a better idea - less work. try get the spray type so that it comes out smooth.
my only experience with duplicolour paints is that they are really fantastic!!! top quality!
- AR 200SX
- 0.2 Bar Boost
- Real Name: Armand
paint
just use base coat paint that you would normaly paint a car with,did a couple of cars and it works great,provided they are nice and clean.just use a paint brush with some benzine.
- Real Name: Nat Wakefield
The only problem with the Duplicolor product, is that there is a time period that you are not allowed to use the calipers after being coated. According the can I have in front of me it says:"... wait 7 days for paint to cure..."
The finish is only as good as the preparation of the calipers to be painted. A well prepared rattlecan job can look just as styling as a powercoat or ceramic coat job.
powdercoating = much more expensive???
what are you talking about?
powdercoating your calipers will only cost about 20 bucks more than a can of duplicolour caliper spray!??? and that includes sandblasting.
the more expensive bit comes in because you have to rebuild the calipers!
