FEELER: Wolf3D V4 EMS
Anyone interested in a Wolf3D V4 system??
- mario_200sx
- mario_200sx
- mario_200sx
- mario_200sx
Not sure what info you want on it.
Tune from either Hand Controller or PC Software
Maximum Engine Speed 20,000RPM
Fuel Map every 125RPM to 16,000RPM
Fuel Map has 16 Load Bands
Ignition Map every 125RPM to 16,000RPM
Ignition Map has 16 Load Bands
Boost Control adjustable every 125RPM
Idle Speed Control with Water Temperature Compensation
2 Fully configurable Auxiliary Outputs
Cam, Crank or Coil Negative Inputs
Multi Coil Ignition Outputs
Sequential Fuel Injection and Ignition up to 4 cylinders
It does EVERYTHING you could ever want it to do.
- mario_200sx
- mario_200sx
