s14 brake rotor size
RBSX
1.0 Bar Boost
Post by RBSX »
whats the size of the s14 brake rotor
280mm x ???
seems i may have s14 calipers and not z32
That would explain them looking different from mine.
AR 200SX
Real Name: Armand
s14
Post by AR 200SX »
28mm.zx uses 30mm on the twin turbo.
s14 calipers are the heavy steel ones. no cooling fins on them at all.
but then the r33 ones also dont have the cooling fins like the z32 alumnium ones!
RBSX
1.0 Bar Boost
Post by RBSX »
28mm hmmm.....ok so do i just buy s14 discs and redrill them to the correct pcd
or can i use 30mm discs
hey does any othe nissan use s14 discs
Sokar
1.0 Bar Boost
Post by Sokar »
RBSX wrote:28mm hmmm.....ok so do i just buy s14 discs and redrill them to the correct pcd
You can put smaller width discs in a calliper, bigger normally doesnt work.
You'll find you cant push the pistons in enough to get the new brake pads over the disc. You can probably skim some material off the pads, but thats hillbilly, S14 disc will be the best bet.
In any case you would need to re-drill to 4 hole.
Captain Slow to the rescue!
RBSX
1.0 Bar Boost
Post by RBSX »
ok im gona measure the width properly
