Pin A - nothing / not needed
Pin B - +12v power
Pin C - ground
Pin D - air flow signal out
65mm
SR20 AFM Nissan S14/200SX
Pin B - +12v power
Pin C - ground
65mm
RB20 AFM Nissan Skyline R32
Wire A - Not Connected
Wire B - Signal
Wire C - 12v Ground
Wire D - Signal Ground
Wire E - 12v Power
80mm Same size and calabration as Rb25 AFM
RB25 AFM Series 1 Nissan Skyline R33 Series 1
Wire B - Signal
Wire C - 12v Ground
Wire E - 12v Power
80mm Can be used on RB26 in twin form as an upgrade from the standard AFM's (ECU Change required)
Z32 AFM Nissan 300zx Twin Turbo
Wire 1 - Not Connected
Wire 2 - Signal
Wire 3 - 12v Ground
Wire 4 - Signal Ground
Wire 5 - 12v Power
Wire 6 Not Connected
80mm Same size as RB20/RB25 but has higher calibration. Should be good for around 350rwkw. Perfect swap into Rb20/Rb25 as bolt pattern is identical and no change is required. RB30 AFM plug fits which can be had very cheaply from any nissan/holden wrecker
Q45 AFM Nissan Infiniti Q45 V8
Wire 1 (White) - Signal
Wire 2 (Black) - Ground
Wire 3 (White & Black --have seen red and black--) - 12v Power
90mm Higher calibration and larger diameter airflow meter. Has been known to go upto 450rwkw. The physical body of the unit is larger and it wont fit standard pod filte adapters or airboxes. It is just over 3.5" in diameter on the outside. The inside diameter is 3".
Quoted from DocterOkay found some more clarity on this:
The MAF I have for sale is from a RB20DET or VG30DET motor. Part # on the MAF is 22680-16V00-AE36-000-N60. This is not the same as a maxima maf. Hence 350whp.
RB20DE(T)
Part # 22680-16V00
RB20DE(T)
Part # 22680-02U00
RB25DE
Part # 22680-02U00
VH45DE
Part # 22680-61U00
VH45DE
Part # 22680-61U01
VG30DE(T)
Part # 22680-16V00
Here are some further MAF information:
SR20DE MAF 91-94 Sentra SER, part # 53J00
50mm 250 WHP-----------Bored 54mm 290 WHP
SR20DE MAF 91-99 200sx SER, part # 53J01
SR20DE MAF 00-01 Sentra SE
325 WHP
91-94 Pulsar GTIR, part # 54C00
50mm 290 WHP-----------Bored 54mm 345 WHP,
Aveneir W10 and W11, part # 54C01
50 mm 290 WHP----------Bord 54mm 345 WHP
Maxima 95-98
325 WHP
SR20VE, Pathfinder 00-04 V6, Xterra 00-04 V6, Frontier 00-04 V6, Quest V6
325 WHP
300zx and 300zx TT 90-96, part # 22680-30P00
80mm 500 WHP
Infinity J30, part # 22680-30P00
80mm 500 WHP
There is also an older 90mm Infinity Q45 maf good for 600whp.
Lastly, for up to 340whp the N60 (16V00) is said to flow more stable than the Z32 N62 MAF.
