Brakes: Rotors
mario_200sx
Brakes: Rotors
Post by mario_200sx »
Whats the difference between floating rotors and solid rotors?
What is the max size you guys think we should go with rotors? Using 17" mags....
Solid and floating calipers, I would hate it if my rotors floated :lol: .
I have Z32 calipers with 335mm rotors under 17inch mags, there is only about 5mm clearance though.
HancoB
Post by HancoB »
Sadly they are floating calipers...
HancoB
Post by HancoB »
Serious race cars use fixed calipers exclusively whenever allowed by the rules.
Manufacturers like floating calipers because they are much cheaper to manufacture, and their lack of positive location is actually a plus in a production application. The ability to float makes these calipers very forgiving of caliper misalignment and/or rotor run out. The downside is crummy pedal feel, as everything moves around and you have to take up the slack. This does not lead to linear brake application, and makes it much harder to keep the brakes on the edge of lockup - which is why you need ABS with floating calipers.
The only functional disadvantage to fixed calipers, be they 2, 4, or 6 piston is that they are very intolerant of caliper misalignment and/or rotor run out. This means that in many cases you will have to shim the caliper and shim and/or true the rotor. What you will get is rock solid pedal with almost no travel. This allows you to "squeeze" the pedal and modulate the brake pressure in a very linear fashion. If you can't effect maximum, edge of traction braking with a properly set up fixed caliper brake system with no ABS, you probably should be playing golf instead.
mario_200sx
Spank you all! 8)
HancoB
Post by HancoB »
Its a pleasure....grrr baby
HancoB wrote:Its a pleasure....grrr baby
:shock: :shock:
The gayness is strong in this one....
:lol: :lol:
mario_200sx
hy moet net weg bly van my af! ek connect hom met 'n floating caliper!
HancoB
Post by HancoB »
Then you should see my lightsaber!!!! beeehoooowwww
Sokar
1.0 Bar Boost
Post by Sokar »
You do get floating discs, look at a superbikes front, you get the center of the disc then there are floating dowels that keep the disc itself attached, but allow a minute amount of sideways movement.
Captain Slow to the rescue!
Doctor G
0.7 Bar Boost
Post by Doctor G »
Anyone wanna attempt to explain monoblock calipers?
300sx
0.8 Bar Boost
Post by 300sx »
floating discs are much more resistant to warping, as far as i know..
mario_200sx
Sokar wrote:You do get floating discs, look at a superbikes front, you get the center of the disc then there are floating dowels that keep the disc itself attached, but allow a minute amount of sideways movement.
Yip, your right Sokar, wnet and did some P.I work (private investigation)
You even get floating rotors for our nice 200sx cars..... hehehehe
Doctor G wrote:Anyone wanna attempt to explain monoblock calipers?
yes google...http://www.freshpatents.com/Monoblock-c ... 289253.php
HancoB
Post by HancoB »
If you follow Formula One, NASCAR, World Sports Car, Champ or IndyCar racing, the winning teams employ calipers machined from one piece of exotic aluminum alloy. These calipers are referred to as MonoBlock units.
