lets see who's done their homewrk!!!???!!!
hey guys...
spot the difference from a normal SR20det motor...
the mod helps to reduce parasitic drag on the crank, and allows you to negate the use of a turbo timer is setup correctly...
mmm... is it that chrome box on the right side of the motor???
Sokar
1.0 Bar Boost
Post by Sokar »
It looks like some sort of primitive hunting impliment.....
:P
Seriaaaasly the only thing outside a motor that I can think of that would reduce crank drag would probably be some sort of crank vacuum system??? Dunno how it ties in with a turbo timer?
Captain Slow to the rescue!
tanaka
Post by tanaka »
sr20dett
Pinkfluffybunnys
Real Name: Ashley
Post by Pinkfluffybunnys »
Cant see Pic...
But is it a crank scraper? Knife-edged crank?
Guy
Post by Guy »
It sounds like you're talking about a dry sump setup.
jon
0.7 Bar Boost
Post by jon »
I second tanaka :D
Looks mean.
eish you guys...
although this particular motor isnt setup the way i would do it, the mod is still properly visible!!!
@waterboy - NO!
@sokrap - NO!
@tanaka - NO!!! but you are looking in the right place!!!
@pinkfluff - NO!!! but i reckon if you saw the pic you might get it right.
@Guy - NO!!! but its a similar concept.
@jon - NO!!! thats not a turbo!!!
shall i leave you all in suspenders for a little longer?
jon
0.7 Bar Boost
Post by jon »
NO, just tell us damnit :lol:
nope - you guys need to think outside the box a little...
clue 1 - reduce drag on crank
clue 2 - none of the above
clue 3 - it can help to prolong the life of the turbo - similar to a turbo timer, but without the turbo timer - although this only works on certain turbos!!!
clue 4 - its outside the motor - not inside
clue 5 - its something similar to a dry sump setup
clue 6 - that motor is not a twin turbo
anybody???
Doctor G
0.7 Bar Boost
Post by Doctor G »
Can't see the pic properly (too small) but the ali crank pulley def reduce drag.
I can also see the PS has been deleted.
And my final guess is an electric water pump. Which leaves the question why the actual WP is still there. But it often gets left behind just running along on a free ride.
300sx
0.8 Bar Boost
Post by 300sx »
looks like its pressurising the crankcase?
Doctor G wrote:And my final guess is an electric water pump. Which leaves the question why the actual WP is still there. But it often gets left behind just running along on a free ride.
nice DrG!!!
looks like one to me, and i also dont understand why they left the original water pump there!!!
go to this link: http://www.daviescraig.com.au/main/display.asp?pid=47
in the davies craig pages they say that a normal mechanical put out 15-20l/min. the davies craig electric pump puts out 80l/min. the pump draws 6 amps from the system when the car is off. and it can be set to be run for a specific time after the car has been turned off! much safer than leaving your car alone while its running!
here's a pic of the system.
and here's a pic of an open box. the oil cooler fan below is not part of the kit!
widowmaker
Real Name: Walter
Post by widowmaker »
i second drG
tanaka
Post by tanaka »
veecee wrote:nope - you guys need to think outside the box a little...
anybody???
brother, dont know what is wrong with my eye but that is a twin turbo setup and where is that thing you talking about in the pictrue.
