help?
AR 200SX
Real Name: Armand
help?
Post by AR 200SX »
does anyone know why a intake cam's teeth wil brake of some of the teeth? chain tensioner? on a sr20det? :?:
Post by Ero_sennin »
howd that happen
you must be talking about hte cams gear teeth - and to me that sounds almost impossible???
thats like 2mm of steel, and a fancy complicated geometric design that should be very strong!!!
so i would've assumed that the chain would break first!!! :shock: :shock: :shock:
AR 200SX
Real Name: Armand
help
Post by AR 200SX »
it's a friend of mine's s14.took it to get it dyno'd @ snail conversions.the guy there said the chain is to tight and put in another chain tensioner,also took out the cas.when they started it again it made one moer of a noise and he said it's faulty lifters. my friend phoned me and a removed the tappet cover to find the teeth broken.about 10-12 of them around the sprocket.
holy crap!!!!
10-12 teeth?
chain tensioner too tight?
faulty lifters???
DUDE!!!???!!! :shock: :shock: :shock:
AR 200SX
Real Name: Armand
help
Post by AR 200SX »
i haven't got a fkn clue.maybe chain did'nt have enough tension? chain stretched?
AR 200SX
Real Name: Armand
help
Post by AR 200SX »
replaced the vvt pulley with the std sr20det's.took out the lifers on the intake side,checked them and put them back with the std chain tensioner and whala,100% :lol:
nice - and now its also ready for some big HP!!!
MyPRodOL
Re: help
Post by MyPRodOL »
AR 200SX wrote:it's a friend of mine's s14.took it to get it dyno'd @ snail conversions.the guy there said the chain is to tight and put in another chain tensioner,also took out the cas.when they started it again it made one moer of a noise and he said it's faulty lifters. my friend phoned me and a removed the tappet cover to find the teeth broken.about 10-12 of them around the sprocket.
things like this really scares the crap out of me...... :shock:
AR 200SX
Real Name: Armand
help
Post by AR 200SX »
just goes to show you,can't some trust anyone.
