My Bent Fuel Rail needs to be fixed
hey guys...
i had a good look at my fuel rail this weekend...
i'm almost sure its assembled with a brased joints, which probably means that the section that is bent can be removed, and replaced.
all i now need to know is where i can take the fuel rail to be fixed. it would need to go to someone with excellent brasing skills...
any suggestions!???!
What.....you meen you and sokar can't fix it with a hammer and a angel grinder.... :lol:
Sokar
1.0 Bar Boost
Post by Sokar »
the fuel rail is still attached to the fuel pump, if we angle grind it there is a risk of fire! I'm a savage, not doff!
Remember kids, safety first....
Captain Slow to the rescue!
can we please be ser-ri-usss on this one ...
PPPPUUULLLEEEEAAAAASSSSEEEE!!!!
so nobody has any ideas then... NICE!
where are all the engineers and guys with connections and stuff???
its just brasing okes... i dont want to build a ceramic tiled rocketship!!!
Post by Vlade »
angle grinder and hammer... I'm being serious... :D
Arg VC... you can buy fuel rail buy the length, cut it to the size you want and braze the ends back on. Brazing is super simple aswell so you will have no problem there.
If the bend is not too excesive you can just heat it up and bend it straight, orange is a good colour :lol: .
Cuzz
Newbie
Re: My Bent Fuel Rail needs to be fixed
Post by Cuzz »
veecee wrote:hey guys...
Where do you stay? I might be able to help.
Pretoria?
jhb...
what you got in mind???
Cuzz
Newbie
Post by Cuzz »
veecee wrote:jhb...
8)
Hay! you can try Media hydraulics. They do silver soldering.
westmaister
Post by westmaister »
I THINK FIRST OF ALL YOU MUST TAKE EVERYTHING OFF THE FEUL RAIL
HEAT IT UP & CHECK IF THE THING IS SOLDERED TOGETHER,IF SO THEN IT WILL BE EASY TO FIX. I THINK BRASING/SOLDERING IS JUST ABOUT THE BONDING SOLUTION YOU HAVE TO APPLY & AFTER THAT ITS PRETTY MUCH THESAME AS SOLDERING IT WITH LEAD OR WHATEVER.
I SAY CUT THE SECTION OUT, GET A RADIUS PIPE THAT FITS EXACTLY OVER THE CUT OUT SECTION,SLIDE IT OVER & SOLDER IT IN LIKE THEY DO WITH PLUMBING.
ALL THE STUFF YOU'LL FIND AT YOUR LOCAL HARDWARE & WILL WORK JUST AS FINE!
