Brake renew
Posted: Fri Feb 15, 2008 10:58 pm
by Phinx
Everyone seems to need a brake upgrade on the SX's , But before we stroll down to the Scrap yard for the 300zx Calipers can I ask the question when last did you change you brake fluid?
Brake fluid needs to be changes yearly because it absorbs moister and breaks down after time with heat
Items you will need:
10mm socket or spanner
peice of clear plastic tube approx 1m in lenght
a glass jar or something you can drain brake fluid into
a bottle (or two) of replacement brake fluid
a friend
The Nissan 200SX braking system requires a non-silicon based brake fluid. This would be a DOT3, DOT5.1 or RBF600 rated brake fluid. DO NOT USE DOT5 fluid in the 200SX braking system as it is silicon based.
The DOT ratings of the brake fluid simply refer to its different boiling.
DOT 5.1 and RBF600 fluids have the highest boiling point of the brake fluids avaliable. This means - they will continue to work even though the braking system is very hot.
Thank you DreamensioN
Pic of my Skanky Brake fluid
New clean fluid.
Posted: Fri Feb 15, 2008 11:12 pm
brake fluid usually is a clear-ish liquid. when it goes black then its definitely contaminated, and as it absorbs water (in the form of moisture) the most common contamination is by water.
so if your brake fluid is a dark colour, its a good idea to change it out.
apply the same principles to your clutch to renew the fluid there too.
as a general rule: if you cant see through it, its dirty and contaminated, and its not performing as well as it should!
if you're brave, or impatient, try to pressurise the brake fluid container for a quick bleed!
