Brake fluid needs to be changes yearly because it absorbs moister and breaks down after time with heat
Items you will need:
10mm socket or spanner
peice of clear plastic tube approx 1m in lenght
a glass jar or something you can drain brake fluid into
a bottle (or two) of replacement brake fluid
a friend
The Nissan 200SX braking system requires a non-silicon based brake fluid. This would be a DOT3, DOT5.1 or RBF600 rated brake fluid. DO NOT USE DOT5 fluid in the 200SX braking system as it is silicon based.
The DOT ratings of the brake fluid simply refer to its different boiling.
DOT 5.1 and RBF600 fluids have the highest boiling point of the brake fluids avaliable. This means - they will continue to work even though the braking system is very hot.
Thank you DreamensioN
Pic of my Skanky Brake fluid
New clean fluid.
