that black car still makes the hairs on my arms stand up...
i really really want one!
did you notice the inside front wheel lift off the ground in the one corner?
did you see how flat it corners?
how stiff that body is?
how nice the engine sounds?
its so wikked!
What about ARB's? would be nice to get in SA *cough*cheap*cough*
Anti-Roll Bars dramatically improve handling. They minimize the traction-robbing body "lean" that rolls part of the outside tires off the pavement. Sport-tuned Anit-roll bars replace skinny OEM bars and rubber bushings with larger diameter (stiffer) alloy steel bars and poyurethane bushings. More roll stiffness means less body "lean", and the tires stay flatter on the pavement (larger contact patches). The result is more grip and added driver control.
Progress Ant-Roll Bars are cold-formed in-house using their custom built precision bending equipment. Both laser-cut and CNC bar ends are MIG welded in place using a precise fixture for an exact fit.
our ARB's are quite staunch to start with. they're are nearly double the thickness compared to other cars of the same era.
there are couple of things that would really improve stiffness, but once you start suspension mods, you never stop.
full rollcage and seam weld is one of the best bets.
lots of strut braces - because there are more than two places for them to fit.
rose/heim jointed suspension arms
thicker anti-roll bars
solid/polyurethane bushes
powerbraces
fender braces
foam filled structural joints
etc.
