Hi all,
I am new to the forum. I am looking for 2 standard CA18DET pistons. (2 of my pistons have broken ring landings). I am also looking for 450cc/550cc injectors for the my buddies SX. His SX is running a TD04 turbo + FMIC + FPR + BOV, everything else standard. Any chip/management options you guys can suggest as car is running dry on top and sometimes cuts out.
Thanks in advance...
Rossi
200sx parts wanted
I have the pistons for you.
Stock Size...
How did you ring lands fail?
Stock Size...
Mazda RX7 13b turbo motors between 89 and 93 (or somewhere there) have 550cc injectors that will fit straight into your buddies CA18det fuel rail.
check it out. its the motor that you can find at most import places, and usually if they have a motor that they cant sell, they will part it out.
otherwise the rotary tuners often have them because thats one of the first things that get replaced when rotary motor owners upgrade!
