Flywheel
- mario_200sx
Flywheel
Mornin all,
Sounds like you all had a great Saturday! So pissed! I was workin!
Anyway, do any of you know if there is any light aftermarket flywheels available for the S13 in South Africa.
- mario_200sx
- mario_200sx
There are Alu Flywheels but they are full imports and very expencive
Also there is a way to get a nice Flywheel for cheap.
The CA18DET motor can be modified to fit a SR20 flywheel, this will allow the use of the much cheaper SR20 Flywheel kits.
But we have to use a special starter then
- mario_200sx
No it doesnt, its a common misconception, its not altering your combustion chambers so your "bang" remains the same, no change in torque.Vlade wrote:I don't believe in it, robs you of torque.
What it does do is rob you of inertia, a flywheel is basically a gyroscopic dynamo (or "mechanical battery" if you'd like) More mass = more stored energy, less mass = less stored energy, basically means a lighter flyweel will absorb (rev up) and loose (uphill driving etc) energy alot quicker...
Interesting read at http://www.damninteresting.com/?p=909
In my personal opinion the CA's flywheel is friggin heavy (heavier than my 325i flywheel) so it can shed a bit of weight, just dont go nuts and make it look like swiss cheeze, we will all laugh at you when it shatters at 7000rpm and cuts you off at the knees, stumpy
Captain Slow to the rescue!
- mario_200sx
well my crank is lighter then my flywheel honestly.
That thing is damn heavy
- mario_200sx
Hmm never picked up a Single lump Idle...
And My cams are alot more aggressive.. Its smoother but does feel slower to me in all honesty
the stock flywheel is 13kg's!
i weighed mine.
then i took it to the engineer to remove "meat".
he did his best, but said that taking off more than 3kg's would make things very dangerous.
i didnt want a life threatening flywheel - so i paid and smiled at my 10kg flywheel!!!
i'm short enough, i dont need to be shorter!
i weighed mine.
