So this spare CA18DET I have doesn't have a throttle body.
On this motor I am looking for lots of low down toque and very fast throttle response, from idle I want to rev fast and smooth kinda like a bike or race motor.
I have been looking at a throttle body for the motor but am not sure which to go for. Do I try fit the stock one back or do I try get something bigger. Will going bigger effect the low speed cylinder filling, bigger bore slower speeds?? What is the size of the stock TB?? Are those universal 70mm throttle bodies any good??
I know individual throttle bodies would be answer but this head is 8 port so that is out of the question, well unless someone wants to swap for a 4 port .
Phinx I know you have done your throttle body so please post you findings.
you just keep the piece with the butterflys. on one side its 4 port and on the other side its 8 port. so its like an adapter built for you by nissan!
then you just need something that will allow you to put throttles on!
also bike throttle bodies are a freely available and common upgrade. the suzuki gsxr has 4X45mm throttles. very nice. and they're mounted with rubber couplings. hmmm... makes life easier too.
My problem is the that the 8 port head will flow less at high rpm and boost than the 4 port will:
The area of the 8 ports are smaller than the 4.
There is a greater friction area on the 8 port than the 4 port, with respect to how much it will flow.
8 port with butterflies is great for a laggy turbo, helps it get into boost.
but you see the bit that has been left on the engine. the bit that holds the fuel rail??? the bit that the throttles bolt onto??? the bit that would hold the 4 butterflies in the 8 port head???
thats the bit i was talking about!
so if you keep the 8 port head - you're going to lose what... 10 horsepower???
