In the first picture below, which of the control arms need to have the outer metal sleeve removed?
From the instructions I know for a fact that D and E below must be cut with a hack saw. The other simply say "remove bush with a press". So this is where the instructions that came with the kit aren't that clear. Does that include removing the outer metal shell? I've burned out the rubber bushing itself already.
Also, why does it state that certain ones need to be cut with a hack saw before removing the shell?
Now, on the spindle, the instructions are very specific that the outer shell labelled "2" must be cut with a hack saw before being removed with a hammer and a punch.
What's the deal with positions 1 & 3? Must their outer metal shells be removed? and if so, must they also be cut with a hack saw first?
