wheel bearing hummmmmmm
antman
- Engine: VG
- Real Name: Tony
Hi people, anyone know were I can source front wheel bearings for my sx, some say they are the same as the Almera fronts but I am not sure as they are FWD. Also need to know who can fix/supply the bush and pin setup on the front callipers as mine rattles over bumps.
Cheers
Cheers
i've done hours and hours of searching for an alternative source of 200sx wheelbearings.
unfortunately i've come out of my searches empty handed everytime.
you probably going to have to go to nissan or find an import option. last time i checked the front wheel bearings where about 1200 each, ex vat!
sorry man - but none of the bearing places stock that bearing, or anything similar to it that might work.
We walk!!Ero_sennin wrote:what?!! And if they go what we do thenGary57 wrote:Nissan dont have wheel bearings nor can they get...
Cant you get sum manufactured or something?
nope.
they're sealed bearings, and they get destroyed during the removal process.
the new hubs deal is probably the best.
but i dont believe that nissan cant get for us. when i went to get quotes from nissan, no-one told me that they cant get. in fact, nissan said it would be a 24 hour delivery delay!
that doesnt mean they cant get, it means they order from japan, and it takes 21 working days for delivery to RSA.
and they wont charge for ordering from japan - its not your problem that they dont have stock!
but to buy aftermarket hubs is a much better deal i reckon. its about the same price and you get new hubs, new bearings, and a 5 stud conversion!!! much better than just bearings from nissan. remember you still have to press out the old ones and press in the new ones!
yeah thats probably the best bet actually.Gary57 wrote:I will take my hubs and have them machined to suit a common brand of bearing, will be able to match the ID and then get the OD machined to suit.
if you do it though, i want to take detailed notes, even more detailed pics, and then post an ARTICLE in the article section.
it can go into mods too, but it definitely has to go in ARTICLES.
OK?
ok!
