Help!! water pushing out thro bottle
zupp
Post by zupp »
hey guys, just need to know urgently:
If water is pushing out thro the bottle after a "hardish run" what could be the problem? There is no water and oil mixing at all. If it is the head gasket, is it a plain and symple head gasket change,head skim and pressure test??
Is this a comman problem on the SX?
What gasket would you recommend and where can I purchase it?
ANY info will be greatly appreciated as I am contemplating purhasing a SX WITH THIS "PROBLEM" but the rest of the car is "sweet"
Thanx in advance :P
Charl
Post by Charl »
there is a chance it might be gasket. i experienced the same problem before mine went and also no water and oil mixing.
there is a certain amount of water that will push out until it reaches its own happy medium water level.
as far as i can understand is there should be a leak somwhere in you system so the water is not vacuming back into the system and instead drawing air. DOES THE WATER LEVEL IN YOUR RADIATOR DROP?
point number one is to check the radiator cap. if its warn and opening prematurely more than a normal ammount of water will push out
200SX Catch my DRIFT?
zupp
H2O
Post by zupp »
Thanx for the responce :P Charl.
I am going to "look" at the car today/tomorrow so I will have more time to check it out properly. Is there a chance tht the gasket is not blown?
Which is the BEST radiator cap to use?
n1smo200sx
Post by n1smo200sx »
The Greddy 1.3bar cap is better than standard 1.1Bar caps.
Import Parts keep them for about R150.
zupp
cap
Post by zupp »
Do you perhaps have an address and or telephone no?
Doctor G
0.7 Bar Boost
Post by Doctor G »
Jsut make sure it's original Greddy 1.3 and not a "Freddy" 0.8 bar cap. The knock off's are very common.
I reckon we should do a group buy on Nismo Radiator caps and Nismo thermostats for all CA and SR and RB motors on this forum one time.
n1smo200sx
Import Parts
Jerry 0828058817
zupp
Post by zupp »
Thx. :wink:
widowmaker
Real Name: Walter
Post by widowmaker »
Doctor G wrote:a "Freddy"... The knock off's
I KNEW IT! :twisted:
and who is this chemcool anyway!
ChemCool
Post by ChemCool »
Carefull, carefull now :twisted: Only speak sense here please :lol:
Chem :twisted:
COOLER, FASTER, LIGHTER
Doctor G wrote:Jsut make sure it's original Greddy 1.3 and not a "Freddy" 0.8 bar cap. The knock off's are very common.
Whats the price on those parts?
MyPRodOL
Post by MyPRodOL »
hope this helps
I never had that problem when the car was stock, but when I started modding, and doing 1 bar from stock motor and turbo it started happening...
and my head-gasket was fine, 100 %. There might be another factor apart from the head-gasket to this issue. I'm not totally sure though.
zupp
Post by zupp »
What "other factor" are you referring to?
n1smo200sx
My motor had a hairline crack in the head,when coming off full throttle it would shoot water out of the reservoir.But the head gasket was also a suspect.
MyPRodOL
Re: !
Post by MyPRodOL »
zupp wrote:What "other factor" are you referring to?
meaning something else, but I don't know... hence "other factor"
