Looks awesome but I'm guessing it's not too usable on the street which would be a bummer.
Those swedes are freaking crazy, gotta respect that
I disagree.
A sequntial setup is all about getting rid of lag. Small turbo spools up early & the bigger one, spools up at the higher and of the rpm band.
Its not the best for outright power, because the smaller turbo starts to hold the bigger one back.
Is all this not evedance to the fact that the next generation of turbos should have the ability to vary the pitch on the blades of the turbo. (eg. turbine props on aircraft)
I disagree.
i disagree - because the small turbo on this setup already looks big enough to cause heavy lag. drive an sx with anything bigger than a t28, boost comes in way over 4000.
