- Real Name: Darryl
Post
by Drillergy »
I fitted a cone filter onto my air flow meter. Its making a sound like a wastegate..,
is this ok?
No other mod's done.
do I have to do any other adjustments after fitting the filter. Someone mentioned CO2 settings.
some positive feedback would be good,
Shot-a-lot
D
e
Sokar
- 1.0 Bar Boost
Post
by Sokar »
Drillergy wrote:I fitted a cone filter onto my air flow meter. Its making a sound like a wastegate..,
is this ok?
Shot-a-lot
D
e
Its normal, the stock airbox muffles the sound but its actually there all the time.
You shouldnt need to set your CO's as the ECU should compensate, but if you have the bucks then it can only help.
Captain Slow to the rescue!
Post
by Riekert »
Yip.
That wastgate sound is quite cool. i also had a cone filter on. but i like the more original look of things.
- Real Name: Darryl
Post
by Drillergy »
Thanks guy's!!
