Braided Brake-lines
Braided Brake-lines
There is a Company that will do Braided Brake-lines for our SX’s but they need a sample.
Estimated cost is R 1100 for all four corners including all fittings
Re: Braided Brake-lines
Is that for first time? Seems a little steep, or is that just my broke self talking?Phinx wrote:There is a Company that will do Braided Brake-lines for our SX’s but they need a sample.
They might give discount for a bunch , not sure...
But you can have them sleaved in a number of colors
- Speed breeder
- 0.7 Bar Boost
- n1smo200sx
- 0.5 Bar Boost
- n1smo200sx
- 0.5 Bar Boost
- ChemCool
Why I asked the question is this: Again this topic is one of those with thousands of different answers. No proof that braided brake lines are betterSteel braided hoses don't expand when you push on the pedal-normal rubber lines do.
than rubber ones.
One dude on the internet tried some test which was well done, but, the results said nothing.
So I am just carefull that it will end up like bling, bling, bling .
I must admit, it will look good, but only for my eyes ownly while lifting up the sx with a jack
Chem
you shouldn't believe everything you read on the internet , hmmm... thats a bit of a conundrum considering what i am about to submit!!!ChemCool wrote:No proof that braided brake lines are better than rubber ones.Steel braided hoses don't expand when you push on the pedal-normal rubber lines do.
it has been proven that steel braided hoses perform better than rubber hose. one dude on the internet isn't much of a reference in an argument against an entire world full of motoring enthusiasts.
not only do the steel lines prevent line flexing, but they also protect more robustly the rubber of the lines that are encased by the steel braiding.
that is protection from the elements, as well as from any friction or heat that they may come into contact with!
ALSO - R1100-00 is a good price. i've been researching this the past two days, because i am only braided lines away from completing my parts collection for the full Z32 brake mod.
It works it falls in a tier 1 package...
Braided Hoses and better pads better brake fluid
Will anyone strip a line off a SX , I would like to getting costing check the fittings and order my set
Read this very <a href="http://www.nsxprime.com/wiki/Brake_Lines" target="_blank">interesting article.</a> <-- Read it already, now!!!
Another <a href="http://www.6speedonline.com/forums/show ... hp?t=76590" target="_blank">debate over on 6Speed</a>, you may have to be a member to view this one, not sure.
