Posts: 2991 Joined: Tue Aug 01, 2006 1:39 pm
Post
by Daniel » Fri Nov 23, 2007 8:58 am
ok at the back of the plenum there are a few pipe nipples. 1 is the PCV valve, the other is the vacuum line for the FPR.
then there are 2 more. i cant remember if they where connected or even need to be connected
if you blow into the one hole it just comes out the other so doesnt go into the plenum as such
any ideas fellas?
Posts: 5723 Joined: Thu Aug 03, 2006 8:32 am
Post
by Draco » Fri Nov 23, 2007 9:18 am
There are 2 nipples for water from the turbo....or one from the turbo I can't remember if the second one goes there aswell...
I remember one going to the brake booster.....
Post
by Draco » Fri Nov 23, 2007 9:22 am
Also if it is a jap spec plenum there might be a extra one for the secondary butterfly vacuum "tank" thingy...but I am not sure
ChemCool
Posts: 2195 Joined: Tue Aug 01, 2006 11:59 am
Post
by ChemCool » Fri Nov 23, 2007 9:37 am
correct
Posts: 2776 Joined: Thu Oct 19, 2006 9:40 am
Post
by Vlade » Fri Nov 23, 2007 9:49 am
I of those lines are for turbo as Dman said, other one is goes into that metal pipe below the plunim.
Posts: 1717 Joined: Tue Aug 01, 2006 4:00 pm
Post
by Ero_sennin » Fri Nov 23, 2007 9:56 am
Vlade wrote: I of those lines are for turbo as Dman said, other one is goes into that metal pipe below the plunim.
Someone's been having to much of the cough mixture.
Post
by Daniel » Fri Nov 23, 2007 10:03 am
oh yeah forgot about the brake booster one.
but im still stuck on the 2. so it comes back from the tubby runs through the plenums back plate out the other pipe and back into the water system
ok then, strange but ok
widowmaker
Posts: 3051 Joined: Wed Aug 02, 2006 9:50 am
Real Name: Walter
Post
by widowmaker » Fri Nov 23, 2007 11:49 am
Ero_sennin wrote: Vlade wrote: I of those lines are for turbo as Dman said, other one is goes into that metal pipe below the plunim.
Post
by Vlade » Fri Nov 23, 2007 12:25 pm
I don't get it, maybe cuz its friday...
Daniel... I'd need your buddy's help, need to have something chucked onto a milling machine with a dividing head, maybe he can assist me
Post
by Daniel » Fri Nov 23, 2007 12:28 pm
Ja sure anytime vlade. i know hes going to capetown this weekend for 2 weeks and then he might go to Namibia for another 2 after, but il talk to him and see what i can arrange
Post
by Daniel » Fri Nov 23, 2007 12:37 pm
is this for your steering hub? i could sort that for you too, butl have to speak to his ballie coz i dont like using his machines while he is away...but shouldnt be a problem this time
Posts: 5975 Joined: Thu Oct 12, 2006 12:56 pm
Post
by Gary57 » Fri Nov 23, 2007 12:53 pm
I know this is a little off topic, but has anyone flowed their intake manifold?? How restrictive is it??
Post
by Ero_sennin » Fri Nov 23, 2007 1:56 pm
Vlade wrote: I don't get it, maybe cuz its friday...
Re-read what you wrote, grammar and spelling was a little iffy.
