As most of the club members know my CA18det has failed again this time taking the bearings with it.
Before I get stuck in on the progress and flow of the build , I have to thank the following people.
Hennie - Thanks for all the support, info and knowledge, and also for the little upcoming something, something for the CA18
Brenwin (Aka Sokar) - Engine pulls make friends or enemy's, You are a true friend, Thanks for the assistance, I really needed hands that day.
My Dad - Thanks For the help and for not burning the SX when it broke again after the 80 th time.
We have the parts we can rebuild him...
New Toys
Now lets get stuck into it, The build if all goes to plan will follow a couple of stages. The stages are Planning, The pull,The strip, The big clean, The Build, The Check and "The Install"
Planning
I think the most important thing is to establish what the motor in question will be used for and the "life" the motor will have. In all honestly, I am getting Sick of fixing the Nissan and the costs are slowly killing me.
So I will do a "final push" , I'm planning on building a Rock Solid bottom end because I have already done the head .
If all goes to plan , I will be looking at a (set) of Aries/Wiseco pistons on top of "Eagle rods", I will not be doing the install / engineering as this is beyond my knowledge base and I will have a company do the install for me following the strict instructions given(In all honesty it quiet cheap having the engineering do the assembly and checking). There work will be check by a few friends I have.
I will be "working" the bottom end for a little more reliability and performance.
The Pull
This must be the easiest part of the project, It's around 30% more work to pull he motor then to pull the head, But you will need a pair of hands, preferably an Engine Stand and a Engine crane or block an tackle.
The engine bay after the pull.
The engine bay after a basic clean
Investigation
The first thing me and Sokar did after the pull was to find the Knock.
But there seems to be nothing wrong , We will examine further
Bottom Ends shots.
Not bad for 170-000km unopend.
The Strip
Well now we are getting into the Stages of most work.
The most important thing about stripping is labelling the parts correct for assembly later
Here we are in the beginning stages.
Striping started
P.s Guys I have also switched jobs so no more surfing the net for me during the day, I will also only be online at night.
