#2. jack up the rear of the s13. put stilts (jackstands) under the chassis arms near the back of the car, because you are going to need the jack again.
once its ass is in the air, place the jack under the diff using a piece of wood between the diff casing and the jack. this protects it, and your wallet!!!
#3. remove the nuts that are on the four subframe mounting points. your jack should be precariously balancing the diff while trying its best not to drop it on the floor.
Remove the front subframe bracket thingy. place the new shiny anodised spacer with the many many step like angles on it (see pic) on top of it, because its going in like that at a later stage!
#4. lower the diff slightly. by slightly i mean enough to get the flattish spacers in the top mounting position. these spacers have a slot cut into them so that you can install them without removing the subframe completely.
#5. replace the front subframe bracket thingy. make sure the shiny aluminium bits are installed. it would be pointless to forget those at this stage!!!
#6. once all the spacers are installed, tighten up the nuts at the front holes, tighten up the rear ones, remove the jack from under the diff, remove the wood, jack the car up again, remove the jack stands, and lower the car back down.
lets hope this mod does not cause your motor to overheat and warp a cylinder head!!!
below are some installed (but not tightened) pics.
