So I am also falling into the trap of wanting to rebuild my engine.
Reasons for rebuild are - small oil leak and temperature problems.
I don't want the above to impact long term reliability and also I want to be able to boost 1bar without any concerns.
I don't know if its a good idea to try and do the rebuild myself. I have never done any engine rebuilds before.
It may be fun to do the rebuild myself, but I don't want to have to end up spending double, as a result of my own ignorance.
If I decide to do the rebuild myself, what tools will I need (measurement tools included), how much will these be and where can I source them?
Items I have learnt I need so far:
Torque wrench
Micrometer
Proper set of spanners and sockets (hex socket for head studs - 10mm)
Block and tackle
Gasket maker/sealer
Engine stand
1 x engineering workshop (to hone/deglaze/bore cylinders+skim head+machine crank)
What am I missing
What parts do I need to replace except for
Gaskets (inlet/outlet manifolds)
Head gasket (ACL racing)
Head studs
Big end and main bearings
New pistons and rings (wrist pins and clips)
(I don't think I am replacing rods - can i make more than 200kw without replacing rods?)
New thermostat
New waterpump
New oil pump (and a lot of oil)
New cam belt and tentioner pulley
I don't have a cam pickup (Removed as I am running Gotech)
How do I measure what size bearings I need? - I see some of you have mentioned that you need oversize bearings - most probably as a result of crankshaft wear and engineering on the shaft.
Same for rings and pistons - oversize/measurement...
Do I need to have the crank engineered as well?
Please don't feel like you'll hurt my feelings. Where I have gone wrong please help...
I'd rather listen now than pay the price later on...
Thanks dudes
