Cam belt question
Cam belt question
does anybody have an idea of how many teeth (on the belt, not on draco) you can be out before you start causing damage? that is my number one suspect for my tractor engine. i think i have slipped a tooth or two that is why my engine gallops i think.
ideas please, before i start taking apart again
supose it would be better to get a good quality one than a fong kong one, which makes, I have no clueGary57 wrote:Does anyone know the part number for the cam belt I will be changing mine this weekend. Does it matter on the make when the motor is making lots of power??
PS: sorry the hijack.
Re: Cam belt question
widowmaker wrote:does anybody have an idea of how many teeth (on the belt, not on draco) you can be out before you start causing damage? that is my number one suspect for my tractor engine. i think i have slipped a tooth or two that is why my engine gallops i think.
Don't be such a useless plick....open the cover and see....1 tooth is enough to make it run like your granny.
is your car smoking? using oil?
probably worn piston rings letting oil through. DONT PANIC!
the easiest way to fill the gap between rings and sleeve is to pour two cups of sugar into your petrol tank. the burning of the sugar makes a thick caramel that plugs that gap up one time like magic.
the coolest thing about this tip is that when driving really fast people behind you will be spun closed with candyfloss!
but noooo, all the idiots go for Prolong
				WooHaa
 - 0.6 Bar Boost
No idea on the part number, but I think you should get it from Nissan. It's only like R230.00Gary57 wrote:Does anyone know the part number for the cam belt I will be changing mine this weekend. Does it matter on the make when the motor is making lots of power??
Steer From the Rear !!
