where can i get:
R/F TRACK ROD BRACKET
R/F TRACK ROD
R/F TRACKROD COVER
R/F LOWER CONTROLE ARM
RF STUB AXLE
R/F STUB AXLE BEARING
R/F STABILIZER ROD
ENGINE X-MEMBER
R/R LOWER CONTROL ARM
R/R LOWER CONTROL ARM REAR
R/R WEEL BEARING
uhm if your lucky enough to find a damaged s14 that has those parts thats probably your best bet, but its difficult enough to find these pieces on an s13.
another option is nissan, but thats gonna be very very expensive!
perhaps the best bet is aftermarket adjustable components for the suspension arms, and then the overseas forums for s14 breakers!!!
there are plenty s14 breakers in the states, the UK, and OZ and NZ. get on the forum, find a breaker and do a deal with the guys there. have them ship you the parts!
veecee wrote:uhm if your lucky enough to find a damaged s14 that has those parts thats probably your best bet, but its difficult enough to find these pieces on an s13.
Dislex had a similar accident, he ended up buying whole other S14 to get the parts......
but those things are pricey - but probably less than originals from nissan.
bearings for s13 are R1200-00 odd for front, and R850 odd for rear. i've searched for bearings from all the bearing places with no luck. they are manufacturer specific so go to nissan. i assume s14 is similar but thats quite pricey!!!
axles will have to be bought new from nissan, or second hand from wherever you can find.
