Hi guys
I was wondering
1)Is there any bigger turbo that you can do a direct upgrade to
i mean like its fits onto your stock manifold and boost pipes and down pipe
i heard some say you could use the T2.8 from s14, sr20det i thinks
2)what boost does a stock S13 run
3) if you buy one of those el cheapo boost controllers that use the valve to control the actuator and up the boost, what is a safe boost to run on the stock turbo, is anyone doing this at the moment
4) whats the maixumum boost you can run on a completely stock engine
thanks guys for all the help and input,
Direct turbo swop and a few other questions
1. yes it does with minor adjustments, you need to grind a small amount away on the manifold and the air intake pipe to the turbo is abit different, quite easy to get that sorted aswell.Gary57 wrote:1. I also heard the T28 was a direct fit but quote me on that.
2. 0.6Bar
3. 0.8Bar??
4. 0.8Bar, heard some people say 1Bar but then I would think you would need a FMIC at least.
2.
3.
4. I boosted 1 bar on the stock intercooler and setup, although in the long run 0.8 is safe for the turbo and engine, I ran a colder spark plug aswell, the best is to do it on a dyno under load to make sure there is no detonation.....
- Speed breeder
- 0.7 Bar Boost
Detonation may occur with the original setup on 0.8 or higher boost, also depends on octance rating of fuel and fueling setup.
I wouldn't run higher boost on a stock motor unless the fuel has been looked at.
Why not get the turbo you want rather, then trying to get one that fits perfectly?
The Calibrator
- VoodooMaster
Hi
I would also like to fit a T28 (still need to purchase one) to replace my current T25 on a CA 18det. Has anyone done this conversion? What was the outcome with regards to performance compared to the standard T25.
What would be the going price of a T28 turbo?
New- ????
Second hand- ???? (in working order)
New- ????
Is Going FAST SIDEWAYS.
pleasant.VoodooMaster wrote:Hi
New- ????
8-10.
2-3.
