GARY!!! - Maybe you can help - Wolf Issues
- Vlade
- * - Club Pimp - *
- Real Name: Barend
Howsit
Got some idle funnies with my Wolf3D sometimes it shoots up to 1500rpm and just stays there, my idle value then remains at 1, when it idle normally the idle value is between 10-20 not sure what exact value...
Any ideas what can be causing the idle to "stick" and just stay at 1500rpm?
Many times it just idles fine, then sometimes it just sticks, I thought it had something to do with the water/air temps but now checked that has no influence...
Ok simple fix, its one of two things. Olny know by trial and error.
1. Your idle valve is set to far open. It is the 10mm nut/bolt on the actual idle bypass valve. Turn this a few turns in and the idle will drop down and the idle value should run up. It is good to have this set at about 100 when the car is hot that why it has enough to drop the idle down when it needs to (your current problem) and enough to open more to give you a fast idle when the car is cold.
2. Your throttle butterfly is set to far open. Simple just lossen the manual stop and turn it down to allow the butterfly to close more. The idle will drop and should pick it back up. Again try get the idle value to about 100 when the car is hot.
PS: Have you had it tuned yet??
Mine does the same as Vlades, sometimes it idles where I set it, then as soon as you come to a stop in traffic or whatever the idle stays up there...next time it is right again.
I closed my idling screw totally, at some stage my car had a nose dive between gear changes as if air escaped somewhere and needed to be built up again, I thaught it might be there so I closed it, that seemed to sort the problem....
I will open it again slightly and see what happens.
