Hey guys was wondering, since all of yall is local and know about the harsh temperatures we have, who has experienced overheating when they fitted an FMIC? and what was done to solve the issue?
My car runs fine with the FMIC, but in bumper to bumper the temperature rises to the red, this has also happend to me on one or more occasion when running sideways for a bit.
My setup 600*300 IC with a set of dual 10" electric fans on the radiator that pulls air towards the engine...
FMIC overheating...
- Vlade
- * - Club Pimp - *
- Real Name: Barend
FMIC overheating...
- Daniel
- Real Name: Daniël
You should block the gaps between the FMIC and RAD (top,bottom and sides) to form a sort of cowling. That way the air passes through both FMIC and Rad instead of escaping thru the gaps and around the rad.
Remembering air takes the path of least resistance.
Im sure it might not sound like much but i hear it works a treat
What is the piping and cooler made of?? Aluminum is the prper stuff too use because, Stainless retains ALOT of heat, hence the reason its used for manifolds. The car will get very hot if you are sitting in traffic, because of heat soak. A bigger radiator is the correct fix, we all know how small/thin the std 1 is.
Hope I dont have this prob when I fit mine (600x300x76mm), have 600x200x65 now. I am in Dbn and this place is MUCH hotter than Jhb.
- Daniel
- Real Name: Daniël
um..i could be wrong but i think vlade's car is starting to get pretty powerfull. We e-mailed ages back. you where stil looking for a replacement clutch hey vlade. Maby you should give us a rundown of whats in now. Did you get that mircrotech ecu...or waht was it that u wanted?
Also a decent 3 core rad will be a huge improvement over the crappy standard job. Maby silverton radiators will have something
- Vlade
- * - Club Pimp - *
- Real Name: Barend
Ummm core size, damn I actually got no idea 50mm??? I know the standard one is 16mm can you believe it
Then there is always the option of ditching the aircon, but don't know if I want to go that route...
I also have an idea that the current waterpump might be on its way out, don't know for sure and don't really care, the rebuild will have an new waterpump.
One of these would have worked pielle
