. I'm willing to let both cars go for 50k including Nistune, zeitronix wideband genuine sparco steering wheel. Original seats one set wrapped in black leather - cost 11k, two sets of original wheels and a set of lenso 18" rims with tires 50% worn. Two gearboxes one damaged ca18 block and head. Tomei poncams perfect working order and arias 84mm forgies. Custom 3 core copper radiator huge. Massive inter cooler good as new custom steel boost plumbing for ca18 *2 different diameters. And a ton of spares that I got from ashley. The red one has poly bushes and short shifter 80mm free flow one high flow silencer and back box no cat sounds amazing
The turbo has 500-1000kms on it. It's a custom journal bearing turbo t28 comp housing gtx comp wheel td04 exhaust housing - I don't know that's what the guy said I don't know what td04 is. And td04 exh wheel. Custom shaft. Internal wastegate and Megan racing equal length manifold all perfect. white car is a rolling chassis red one motor is damaged.
Contact eugene 082six00887three
2x s13 for sale
2x s13 for sale
- Attachments
- IMG_0616.jpeg (300.64 KiB) Viewed 15268 times
- IMG_0614.jpeg (191.78 KiB) Viewed 15268 times
- IMG_0613.jpeg (122.5 KiB) Viewed 15268 times
- IMG_0612.jpeg (283 KiB) Viewed 15268 times
- IMG_0611.jpeg (235.39 KiB) Viewed 15268 times
- IMG_0610.jpeg (350.66 KiB) Viewed 15268 times
- IMG_0609.jpeg (350.25 KiB) Viewed 15268 times
- IMG_0608.jpeg (323.34 KiB) Viewed 15268 times
- IMG_0607.jpeg (313.34 KiB) Viewed 15268 times
- IMG_0606.jpeg (245.03 KiB) Viewed 15268 times
- IMG_0605.jpeg (337.89 KiB) Viewed 15268 times
- IMG_0603.jpeg (365.04 KiB) Viewed 15268 times
Re: 2x s13 for sale
Wow, kind of sad to PFB's old car in such a state.
That car was massively potent as a daily with the GT28RS it had, and he had spent a lot of time and effort in building it.
