My CA running on 3 cylinders only.
SMKNG ACE
Post by SMKNG ACE »
Ok guys.
I was driving from work the other day and while cruising i hear the car starting to sound like a WRX.
Just for a half a km or so then all is fine she ran great again.
Got home and switched off.
Next morning went to shops and back about 3 km and as i pull in at home there again in 3 cylinders ever since.
What i did so far is as follows:
Checked for spark. No 4 got no spark.
Changed spark plugs.
Changed coil packs and still no 4 no spark.
Did check my CAS Fuel injectors and fuel press and a good compression test and all good.
Not sure if it can be the ignitor or a wire break in the loom somewhere ?
Need some input as this is baffling me. :?
Thanks In advance guys. [smilie=200sx_200sx.gif]
Re: My CA running on 3 cylinders only.
If I remember correctly there's a earth wire that earths the coils loom, make sure it's still connected.
Did u do a compression test out of intrest
SMKNG ACE
Post by SMKNG ACE »
ok did check earth but will go double check.
Reason for compression test is that i did the cylinder head last year October and thought the gasket might have blown.
Also to ease my mind that the cylinders is healthy reading about 150-160 psi.
When i have time i will go check the wiring for continuity and also check all possible earthing points.
Injector not blocked
SMKNG ACE
Post by SMKNG ACE »
injector is functioning 100% .
When changed plugs it was wet covered in fuel.
jdm200sx
Real Name: Ridwaan
Post by jdm200sx »
Does it misfire all the time or when car has warmed up? Had similar issue
SMKNG ACE
Post by SMKNG ACE »
Yes it is constant at startup and definitely a dead cylinder.
I disconnected the fuel injector until i can sort it out.
I only drive if it is extremely important.
:evil: Give back my cylinder ... :mrgreen:
jdm200sx
Real Name: Ridwaan
Post by jdm200sx »
See if a fellow friend will borrow you an ignitor to try. Im very sure thats the problem
jdm200sx
Real Name: Ridwaan
Post by jdm200sx »
Where about are u?
SMKNG ACE
Post by SMKNG ACE »
my thought also the ignitor or so ... i am staying near Simon's Town in Glencairn.
Otherwise i should just get a management system fitted.
jdm200sx
Real Name: Ridwaan
Post by jdm200sx »
I have 1. Can u pickup in ottery?
SMKNG ACE
Post by SMKNG ACE »
sure if it is ok must i travel with my car or pick it up rather with the bike if weather permits ?
Oh and just say when and where.
Thanks hope this solves it.
jdm200sx
Real Name: Ridwaan
Post by jdm200sx »
Come with your bike if you can. Its a bit of a distance to drive on 3 cylinders. You can pick it up and try it. Hope it solves ur prob
SMKNG ACE
Post by SMKNG ACE »
Thanks a mil.
Lets say tomorrow afternoon after work or definitely on Wednesday. Will let you know.
My Cell is Zero 79773 Zero 121 (Michael)
