turbo inlet and outlet
Posted: Wed Aug 05, 2015 10:05 pm
by RaceBreed
- 2015-08-05 21.46.44.jpg (651.57 KiB) Viewed 17301 times
whats up guys!!
can anyone tell me which is the oil inlet and which is the oil outlet on my turbo
Re: turbo inlet and outlet
Posted: Thu Aug 06, 2015 6:56 am
Top pic in, bottom pic out
Posted: Thu Aug 06, 2015 10:30 am
Posted: Thu Aug 06, 2015 5:15 pm
by RaceBreed
Schweeet gents thanks
Posted: Thu Aug 06, 2015 10:50 pm
by RaceBreed
My turbo is also water cooled so where would the coolant lines from the turbo go into the engine(rb25det neo with greddy intake). When I bought the motor it pretty much came as a naked engine. Stripped of its pipes and fittings
Posted: Fri Aug 07, 2015 7:11 am
Get a FSM and see where the original lines ran from.
Posted: Mon Aug 10, 2015 4:16 pm
by RaceBreed
I didn't even think of that haha
Posted: Fri Aug 14, 2015 4:42 pm
by RaceBreed
I'm struggling to find the answer I am looking for on the good'ol interweb. In which direction does the engine coolant flow. I have a greddy intake.
Posted: Fri Aug 14, 2015 5:07 pm
by andre_sx
Posted: Fri Aug 14, 2015 5:13 pm
by RaceBreed
Thanks for the link but doesn't mention flow direction.
Posted: Tue Aug 18, 2015 7:51 pm
by RaceBreed
Please can someone who knows advise me
- What's up fellow sx addicts ; ) what are these marked 1, 2 and 3?
- 2015-08-18 17.37.46.jpg (768.12 KiB) Viewed 17174 times
Posted: Tue Aug 18, 2015 9:12 pm
2 is oil feed, 3 is water return. Not sure what 1 is, my SR doesn't have that...
Posted: Tue Aug 18, 2015 10:57 pm
by troopiec
Is 3 not turbo oil return? turbo coolant lines are 8mm hoses max usually
Posted: Tue Aug 18, 2015 11:36 pm
by RaceBreed
ok i figured out that 1 is turbo oil drain back, 2 is turbo oil feed and 3 is oil drain from head(rear) .Thanks guys
now to figure out where the turbo coolant feed and return go from the turbo...?
Posted: Thu Aug 20, 2015 12:54 pm
by troopiec
Just find the 2 coolant connections that are left unused, coolant feed and return can be connected either way onto the turbo aslong as it's a closed loop. And remember turbo central core must be positioned/rotated so that oil feed is ontop and oil return at the bottom for gravity to return the oil correctly
