Hi guys .....own the rezlo built s14 , with rb . Don't drive her often enough. Started her up yesterday and took her through her stride. All went well. After a while noticed that the apexi screen , went to the apexi logo on the screen. Didn't show the temp and knock which it was set too.
Must add that the car is standing for long times and the batt runs down. On ,my last drive forgot to remove the batt lead. Before the drive today , just slapped the charger on and charged. Started first time and all was well. The Apexi management showed the temp and knock and when it was warmed up , took it for a mild and then then wild drive....
The car still drives , no hiccups , just the screen showing no info. The buttons are freezes and u can't push anything on it.
Help , any input would be appreciated....don't wanna drive her like that , just need some pointers as to what it can be or where to look or some reset methods or something ...
Tanx
Apexi management
Re: Apexi management
Surely you should ask Rezlo as he fitted it... Prob knows better than most...
agreed
I know he will know best , will try ask him. So If I understand correct , this has never happend with any other one on here.
But Tanx anyways ...will speak to him ...
- Charlvdw
I don't think here are to many with your exact setup.Demonic wrote:I know he will know best , will try ask him. So If I understand correct , this has never happend with any other one on here.
sounds like new hand commander time or try resolder any dry joints in the unit
a fool by his own.
a fool by his own.
