Speed breeder
0.7 Bar Boost
Posts: 741 Joined: Wed Jun 06, 2007 10:19 pm
Post
by Speed breeder » Wed Jul 01, 2015 12:19 pm
Hi guys, looking for the following for my SX:
Hubs, calipers and rotors for S13 to convert to 5 stud.
CA18det t3 top mount exhaust manifold... mine sort of melted under pressure
Or if someone can make me a better quality one...
Thanks
z
Posts: 3882 Joined: Wed Jan 09, 2008 10:08 am
Post
by Charlvdw » Wed Jul 01, 2015 12:40 pm
Speed breeder wrote: Hi guys, looking for the following for my SX:
Huh?
Posts: 2512 Joined: Wed Aug 17, 2011 9:10 pm
Post
by SonOfAnarchy ZA » Wed Jul 01, 2015 12:53 pm
melted
did they make it out of pvc or something
Post
by SonOfAnarchy ZA » Wed Jul 01, 2015 12:54 pm
i have front and rear stock disks
Speed breeder
0.7 Bar Boost
Post
by Speed breeder » Wed Jul 01, 2015 3:23 pm
yep, some pieces fell off...obviously not good quality steel was used in fabrication- was an import item.
hey son, you have 5 hole discs?
Post
by SonOfAnarchy ZA » Wed Jul 01, 2015 4:42 pm
no 4 hole but just redrill them to the correct pcd and holes u want
Speed breeder
0.7 Bar Boost
Post
by Speed breeder » Wed Jul 01, 2015 5:38 pm
that and the hubs I suppose... would be a cheaper solution than ichiba hubs
Posts: 493 Joined: Mon Dec 26, 2011 11:00 pm
Post
by troopiec » Wed Jul 01, 2015 7:23 pm
Can't modify stock hubs that you have to replace if you want 5 hole but you can drill 4 hole discs to fit 5 hole hub
Posts: 2078 Joined: Fri Sep 21, 2007 10:18 am
Post
by Drillergy » Wed Jul 01, 2015 7:46 pm
I got S14 disks and calipers.
5 hole. front and rear, disks. Good condition.
Front calipers arent 4 pot though. Thought all S14s came out with 4 pots up front.
Can anyone confirm.
Post
by Charlvdw » Wed Jul 01, 2015 9:54 pm
Het jy nog die jig?
Posts: 9505 Joined: Tue Jul 31, 2007 11:51 pm
Post
by Riekert » Wed Jul 01, 2015 10:40 pm
Can mod front hubs but not rear
Enzio wrote: Who needs ligths? When you're going sideways forward facing lights don't do anything but confuse squirrels and sheep next to the road...
Speed breeder
0.7 Bar Boost
Post
by Speed breeder » Thu Jul 02, 2015 3:09 pm
@Charl - yep het nog die jig...dis actually net wastegate pyp wat `n issue is, maar almal is te bang om aan dit te werk. metaal lyk dun
@Darryl - great stuff - will send you whatsapp for prices.
@Riekert - great... so ichiba is the only way then for no mess no fuss solution
Post
by Riekert » Thu Jul 02, 2015 3:12 pm
Pretty much. I know you can use the n/a 300zx rear hubs which will fit with little effort.
MOOSE248
Posts: 54 Joined: Tue Jul 30, 2013 9:16 pm
Real Name: christopher
Post
by MOOSE248 » Tue Jul 14, 2015 7:26 am
I have 5 whole disks and skyline calipers
Speed breeder
0.7 Bar Boost
Post
by Speed breeder » Tue Jul 14, 2015 3:37 pm
hey Moose248, how much did you want fo the discs and calipers?
