The Calibrator
Post
by The Calibrator »
Interim dyno
Low boost low compression
0.7bar
202wkw 348nm Just goes to show what cc's cams and head work can do.
Post
by Gary57 »
WOW that is very strong. What was done to the head??
Doctor G
- 0.7 Bar Boost
Post
by Doctor G »
SR22DET?
Phinx
- 0.7 Bar Boost
Post
by Phinx »
ITB
Custom Intake
CC combustion Chambers
Extensive head work
Cams
2.2 and 0.7 bar ...
Looks like a Gti-R SR20DET, Very nice .
At what RPM was peak power? Also what Turbo you using?
The Calibrator
Post
by The Calibrator »
ITB
Custom Intake
Extensive head work
Cams
2.2 and 0.7 bar ...
Some corrections are needed
No combustion chamber work
Smoothing of ports nothing major at all
SR20DE not DET not GTIR
T3T4 turbo
0.4bar 163kw@5900rpm
0.7bar 202kw@5942rpm
348nm@5239
1bar
230.5kw@6318rpm
396nm@5371
1.4bar
260kw@6300rpm
445nm@5600rpm
More power to come after I adjust the cam gears
n1smo200sx
- 0.5 Bar Boost
Post
by n1smo200sx »
post the dyno sheet.Want to see the power graph.Not bad!!!!
The Calibrator
Post
by The Calibrator »
Dyno graph will follow when I am done tuning it.
Post
by Gary57 »
How long do you spend tuning a car like this, dyno time and road time??
