Wastgate spring
Posted: Thu Mar 19, 2015 10:21 pm
by k.y.l.e.
Hey guys looking for 38mm 1bar spring and up so 1,5bar will be fine aswell or does any body know were i can get one thanks.
Re: Wastgate spring
Posted: Mon Mar 23, 2015 1:30 pm
by k.y.l.e.
Anybody?
Re: Wastgate spring
Posted: Tue Mar 24, 2015 9:11 am
by GameBoy
You can try KS Motorsport, they sell wastegates:
http://www.gumtree.co.za/a-replacement- ... 0000048909
Don't know if they sell the springs separately.
Re: Wastgate spring
Posted: Tue Mar 24, 2015 8:53 pm
by troopiec
Flat four racing in killarney gardens can source all springs for excell, but you only get 0.4bar and 0.8bar last time i asked them. to raise boost above 1bar you'll need to add pressure ontop of diaphram with controller to help the spring keep more boost.
Re: Wastgate spring
Posted: Wed Mar 25, 2015 7:15 am
by k.y.l.e.
Thanks guys, Ffr only has 0,5bar springs i called them and you do get wastgate springs that are above 1bar would prefer getting right spring as to stack spring as if spring pre-load to much after a wile due to heat spring will lose its tension and result in losing boost ect.
