Wastgate spring
- k.y.l.e.
- Real Name: kyle
Wastgate spring
Hey guys looking for 38mm 1bar spring and up so 1,5bar will be fine aswell or does any body know were i can get one thanks.
- k.y.l.e.
- Real Name: kyle
Re: Wastgate spring
Anybody?
- GameBoy
- Real Name: Roscoe
Re: Wastgate spring
You can try KS Motorsport, they sell wastegates:
http://www.gumtree.co.za/a-replacement- ... 0000048909
Don't know if they sell the springs separately.
Re: Wastgate spring
Flat four racing in killarney gardens can source all springs for excell, but you only get 0.4bar and 0.8bar last time i asked them. to raise boost above 1bar you'll need to add pressure ontop of diaphram with controller to help the spring keep more boost.
- k.y.l.e.
- Real Name: kyle
Re: Wastgate spring
Thanks guys, Ffr only has 0,5bar springs i called them and you do get wastgate springs that are above 1bar would prefer getting right spring as to stack spring as if spring pre-load to much after a wile due to heat spring will lose its tension and result in losing boost ect.
