CA18DET short block (sump, block, crank, rods, pistons, block fittings and covers)
Engine had OE pistons in. Piston 4 suffered ring land failure and scored the bore. Crank looks to be in very good condition.
It is stripped so you can inspect it yourself if you want.
2x CA18DET heads.
One is toast and should be stripped of valve train that can be re-used (valves, springs, retainers).
Other looks OK but has one broken valve.
R500 for the lot. I am chucking it in the bin next weekend.
CA18DET short block and heads - GONE
Re: CA18DET short block and heads
Didn't get a chance to chuck it away this weekend, so the sale is extended for a week.
