after a bit of driving around and tweaking i got it to where i wanted it, at approximately 0.9bar. happy with that setting i made a cut mark on the tap and the controller to be able to see my benchmark for further tweaking in future.
Then the next day i got in my car to take it to work, drove it a few blocks to get warm and i started boosting it, and dam did it feel good, i checked my gauge and i saw in 3rd gear i was now getting 1.2/1.3 bar boost, i thought woah thats not normal, i pulled over got out and checked everything and nothing came off and all was how it should be, so i got back in and drove some more and after a few half boosts (scared to boost full rev up to 1.3bar) and after a while the boost level then settled again at 0.9 bar and didnt peak or go over and all was as it should be again without touching anything, it seems it does this everytime i drive the car after its stood a while, i did some reading and saw some people say its due to the wastegate temperature, the spring is maybe not hot enough yet and it changes the way the boost reacts, but i never ever had such issues with the wastegate when i was running it straight vacuum from compressor, it would never go over 0.7 bar no matter how hot or cold it was, it would be stable, only since installing the controller im having this boost problem.
i also had the controller set up like this for a bit:
and i managed to get it also to around 0.9 maybe a bit over but i couldnt really test it fully as a vacuum hose tore and it overboosted and i thought it was the layout so i reverted back to the first setup thinking it was safer and less complex so less to go wrong, plus i read you only want to use top boost nipple on wastegate if you want to raise boost high above 1bar.
at the moment i have a standard Excell 38mm wastegate with a 0.6bar spring fitted.
What do you guys think is the problem and how could i fix it, if i turn the boost controller down then when its cold it boosts 0.9-1bar but then after boosting a while it drops to like 0.7 which is lower than i want it, i dont know what to try.... would connecting to the top port give me a more stable boost? or could it be a faulty boost controller, i got it brand new from mr turbo and its the first time im using it.
