timing broblem please help
I am new to this site so hi to all 200sx club members
Ive redone the hole engin with a set of ARIAS pistons but the ignition timing is 25 degrees before TDC can not get it to 15 degrees before TDC.
and my crank angel sensor is turned fully clockwise what can i do to fix this probem thanks.
Agreed check the cam timing its happened to me before.
do you still have the keyway to line up the CAS or has it broken off?
Because you can put it a tooth out if so.
that is what i was looking for on the velve timing i even counted the cambelt teeth between the crank and the cams.every thinng is on spec this is how i installed my cam belt i lined up my crank to TDC thats the second mark on pully then my cams the ex cam first then the intake i spended 12k on this engin and it doesnt look good for me
Nissan The Only Way To go
Very bad Blow-by will do that
Check you PCV system and do a Compression Test.
