sales@fuelperformance.co.za
1 x PHENIX INDUSTRIES KIT (with AN Fittings & Gauge) - R2399
http://fuelperformance.co.za/index.php? ... duct_id=83
1x FUELAB KIT (with AN Fittings & Gauge) - R2600
#51502-1
FUELAB® 515 Series Fuel Pressure Regulators are designed with performance and flexibility in mind. They accept port style and non-port style union fittings without interference. Several configurations are available, supporting carbureted applications as low as 1 PSID to fuel injected applications up to 125 PSID. The 515 Series Fuel Pressure Regulator has a -6AN return port located on the bottom.
-6AN Inlets / Standard Seat / EFI (25-90 PSID)
Regulator Features
•Two -6AN inlet ports and one -6AN return port
•Gasoline, diesel, methanol, and ethanol fuel compatible
•Billet Aluminum with anodize per military MIL-A-8625, Type II
•Fine thread pitch for precise pressure adjustment
•Versatile mounting bracket and stainless steel hardware
•1/8” NPT gauge port with plug for external pressure gauge
•1/8” NPT pressure reference port with barbed fitting
•Backed by a 2-year limited warranty
