Mods for my baby
Dunn
- Real Name: Ryan
Mods for my baby
hey sorry for not introducing myself properly yet,guys
But i have a stock standard 200sx
thinking of some mods but just basic bolt ons for the meantime
Frount mount intercooler
HKS SSV dumpvalve
now here's is the thing
Exhaust 63mm straight with one box at the back or
76mm (any recomendations)
Also lookin at a performance filter,
Cone or Mushroom and why is the HKS mushroom so pricey compared to the Simota just sum advice guys,any otha bolt on mods that i'm missing or which could already enhance such a great car(remember i coming from a Rsi conquest)would be a great help
HKS SSV dumpvalve
ex Accord Type S
ex Impreza STI ver 6
ex 97 Civic Vtec
ex 99 conquest 20v
ex Conquest RSI
ex Accord Type S
ex 97 Civic Vtec
ex 99 conquest 20v
ex Conquest RSI
the 76mm exhaust would be better. Back pressure in a turbo exhaust system is evil, the less back pressure the better. But just watchout what the std computer might do because of the low back pressure, Im not sure.
If you are going to be running the std ECU dont put a dumpvalve. You need to put a recirculating BOV on. If you just dump into the atmosphere you will momentarily run rich and the run down (as soon as you tap off) because you are leaking out measured air. This is obviously not good for the turbo.
- Daniel
- Real Name: Daniël
The turbo will be fine, you'l just run a tad rich everytime you get off the go pedal with a bov. TBH the fuel consumption increase was so minimal on mine i didnt even notice it while i still had my BOV.
The only problem with a larger exaust is that it will show earlier that your turbo seals are on their way out, the lack of back pressure could pull oil through the seals into the exaust with the standard tubby. A diffrent turbo or changing to a 360deg thrust bearing will sort that, or a real cheapy is the one way valve trick on your cam cover breathers
WooHaa
- 0.6 Bar Boost
Daniel is absolutley right.
I did that on purpose, as the richier mixture cools down the combustion chambers as well, which means no holes on the pistons.
I also have only one back box & a real small one at that. The car has become very heavy on fuel since this conversation, but spools up alot faster tho'.
I just need a front mount Intercooler & then I can get the management system.....I just want 145KW on the wheels, is that so much to ask.
Steer From the Rear !!
Dunn
- Real Name: Ryan
]Daniel wrote:The turbo will be fine, you'l just run a tad rich everytime you get off the go pedal with a bov. TBH the fuel consumption increase was so minimal on mine i didnt even notice it while i still had my BOV.
The "the one way valve trick on your cam cover breathers" please explain
ex Accord Type S
ex 97 Civic Vtec
ex 99 conquest 20v
ex Conquest RSI
ex Accord Type S
ex 97 Civic Vtec
ex 99 conquest 20v
ex Conquest RSI
- Daniel
- Real Name: Daniël
Take a trip to a local scrapyard and find a car with a decent sized engine. Look for the hose from the brake servo to the engine, there should be a small valve, remove it (take some of the pipe). Check the valve (you should be able to blow through one end and not the other). Fit the valve between the engine breather and the air intake. The valve must allow the engine to breathe out but not suck in.
I havent got one mind you, Id prefer to remove the breather to the air intake all together. No reason other than id like a hard pipe and that breather bugs me
Daniel, Freddie was right, you touched on my problem I had all the time, my car does not have the connecting breather pipe across to the intake and pvc valve side, I remooved the copper washer(valve) and my problem of smoke and oil in the boost pipes is gone, basically the oppisite of what you are explaining to do in the "trick".
Yes, the left side tappet cover breather pipe goes from tappet cover straight to pvc valve, other side straight from tappet cover to turbo air intake, no washer (valve). I don't know where she breathes but she does now, as I said before I took the washer out..shit guts oil watewa..now fresh air.
As soon as you or someone figures it out let me know...
I am still not sure on what washer/valve you are talking about, mine never had one. My valve to the plumen/intake is blocked off, I dont know what pressure it is good for and would hate for it to leak when its under boost. The one pipe from exhaust side connects to the pipe on the front one on intake side. The other goes into the turbo intake. Do you all breathe into the turbo intake??
