Price R6K
Turbo specs:
TW15 Turbine Wheel (10 Blade) T4-2.5 (61.7mm-74mm)
TH04 `Turbine Housing T3 A/R.63
CW09 Compressor Wheel T61 (61mm-91mm)
CH07 Compressor Housing T04E A/R.70
BP06 Backplate T04E Big Shaft Anodised
BH10 Bearing Housing Big Shaft-Dry
HS02 Heat Shield T4
BOL01 12 x Bolts M8 x 16 * 12
CC04 Compressor Clamps T04E * 3
TCL01 Turbine Clamp T4 * 3 ball bearing
RK10 Ball Bearing kit (Big Shaft)
only thing i did was got compressor housing polished and the imbossed ar sign polished flat
