Ultimate RB25det with EVERYTHING
MyPRodOL
Post by MyPRodOL »
RB25DET and driveline, with only the best bits fitted.
This is a near complete turn key package for your S13 or S14.
The motor and all of the parts listed is currently fitted to my S14 project so test a test drive can be arranged prior to motor etc being pulled. The entire engine has been refreshed so all is as good as new.
The current GTX turbo setup fitted is a lethal street setup making 380kw and 650NM at 2 bar boost. Minimal lag with high end power, usable and enough to destroy some top end super cars with everyday car reliability.
All parts supplied and engine built by Rezlo.
Parts list:
Management:
Apexi D-jetro management R33 GTR
Apexi Dual map and IAT sensor kit R33
Dakota Digital taco adapter
R33 complete wiring harness
Engine and driveline:
RB25DET Engine out of R33 S1 w/ Vin plaque
RB25DET Gearbox out of R33 S1
R33 front cross member modified and reinforced
Oil drain kit fitted to rear of RB head for quick oil drainage.
CP forged pistons
Eagle Connecting rods w/ARP bolts
Machined oil return galleys
Ported head and intake manifold
ACL race engine bearings
Tomei head gasket
ARP head studs
ARP main studs
Tomei Valve springs
Tomei 256 degree Camshafts
Tomei Oil restrictors
Tomei oil pump drive
Nissan 90 mm Throttle body
Nissan R34 injector resistor pack
Greddy oil pump
Nissan N1 water pump
Nissan Timing kit
Nismo Thermostat
Nismo Flywheel
Nismo Stainless clutch line
Nismo twin plate 1000nm clutch kit
Nismo gasket kit
Nismo Oil and Radiator caps
Greddy exhaust cam gear
Greddy timing belt
Greddy Intake manifold
Greddy Fuel rail
Greddy RS blow off valve
RC 1000cc injectors
Splitfire ignition coils
Denso iridium sparkplugs
Silicon radiator hoses
Koyorad thick core radiator
Precision Engineering kevlar PS&WP belts
Rezlo 3L stainless steel dual inlet catch tank
Rezlo 76mm 1pc drive shaft
Rezlo windage high cap oil pan
AB88 breather and fuel lines
All driveline oils - Redline
Turbo pack: (Entire list not even 1000kms old)
Garrett GTX 3576R turbo ceramic coated.
Tial MVR wastegate 44mm water cooled
AN fittings used for all oil and water lines to and from turbo
Rezlo custom built twinscroll turbo manifold (based on the Fullrace design) – ceramic coated
100mm custom downpipe specially grafted for this setup to fit in S14 or what you have – all ceramic coated.
All the above: R150 000-00
Reason for selling, project is taking a drastic change in usage and therefore needs to be adapted for the new role.
If you think this is allot, start counting up how much it will cost to do this kind of build.
PM me for further stats, pics etc etc.
Extras to be sold separately:
D2 356mm 8pot big brake kit – barely used: R15 000-00
Enkei PF01 light weight forged MAT wheels 4 (18 x 9.5J – 114 PCD – 35 offset) : R15 000
Tenzo DC6 wheels set front: 18x8J – 114 – 35offset and rear: 18 x 10J – 35 0ffset: R9 000
Re: Ultimate RB25det with EVERYTHING
Glws.
MyPRodOL
Post by MyPRodOL »
Just as a side note.
If anyone with S13 or S14 is interested in this, we can discuss swapping out SR20det plus difference for this setup.
sly gxi
Real Name: Brendan
Post by sly gxi »
glws man, this is a dream setup . well built and really powerfull
