CA18det camshaft cap order
NITRO-P
Newbie
Real Name: Pieter
Post by NITRO-P »
Can someone please help me with the caps on cams, this is my first build and still learning.
What does the I and E stand for on the caps and witch way does the number go on the cams. Cause I am
sure its must go on the right way, I never took note wen I took them of!!!!!!! I have the manual on the s13
but it says nothing about the Cap numbers :roll:
Re: CA18det camshaft cap order
Probably intake and exhaust. 1 is from the CAS.... 4 is close the gearbox. Thats the usual order. Anachy will confirm, Im more familiar with SRs.
Download factory manual... It's all in there.
Jap 1 is front 4 is gearbox side. Have a look on the front of the cam one will have a key with a half shape moon in it(if the moon hasnt broken off) thats ur exhaust cam which goes on you right side. Cap number 1 should hold the cam seal in
