New S13 Rebuild
New S13 Rebuild
I am Stating a new S13 rebuil in South Africa. I own a panel shop and love the S13[/img]
Some of the damage
Just some of the damge. I have registered so that I can post pictures. You will see it built stage by stage.
Information
Some info on the car and repair.
This vehicle was damaged at very high speed so it was bent hard. I would not usually take on a project like this but these cars are worth it.
I also have the resources to do the job properly. I have stripped the car completely. I need to know there are no other damages and to prevent rattles and loose parts. When im done it will be sick.
Before the car was damaged it was running a CA18 turbo motor, which I will replace with a SR20DET. I am a big fan of that motor. I run it in my Mazda Etude, I will post a pic of that project which is now completed. The 200SX has a two way limited slip diff from the states and Koni adjustable suspension. Upgraded fuel pump and regulators.
So the base is very good. I will explain the build as we go along. It should take 3 weeks with the paint.
Finished Project
It runs a SR20DET motor
On the bench
Hey guys we have put the car on the bench now. There is a lot of work with this one. Yes it is Mikes ex car. Thanks for the comments let me know what you think.
Jerome
