would it cause a problem...
What would change if I took the thin black pipe from the power transister to the turbo air intake pipe(black rubber pipe from AFM to turbo air intake) out and keep it out, would I drastically influence something?
Re: would it cause a problem...
you need to block the hole that it came out of.Draco wrote:What would change if I took the thin black pipe from the power transister to the turbo air intake pipe(black rubber pipe from AFM to turbo air intake) out and keep it out, would I drastically influence something?
also, that little thingamijiggy (solenoid) controls the fuel pressure if your system is stock.
mine is completely gone, BUT... i am running an AFPR directly off my manifold, and i have mechanically set my idling!
Like what was said earlier its the Idle control Valve...
I wouldn't remove it there is really no need to and the car Idles like Cr@p without it when cold. Trust me.
It controls the fuel pressure Via Vacuum by not allow Vacuum to the FPR it can increase the fuel pressure and the fuel injected at Idle
