Item(s) for Sale?: Nistune Type 3 Board in ECU
Price: R2500
Overall Condition: Excellent
Item Location: Pretoria
I am willing to ship (Yes/No/NA):Nope
Contact Details
Phone: 082 Five 33-1277 (Can WhatsApp)
Good Afternoon Guys and Girls
I am selling the Type 3 Nistune Setup (In ECU) that was fitted to the GSI.
This is a Plug and Play mod, Just Unscrew your Old ECU and Install the Nistune Unit (Sales Doesn't Include ODB Consult cable and Licence) but I will supply you with a old Consult Cable (that needs repairs(Soldering)) and supply you with the maps. (Licence is your expense)
I am also willing to give a demo , To any interested party by plugging in the Nistune into your car and running a Uprated map, Will work great on a Stock to Mild DE or VE as I have all the Maps.
Please Note This Will only work on New Spec 200GSI\STI or GXI's, P10's
NIStune is a real-time tuning suite designed especially for Nissans which provides the ability to:
• Retune factory Nissan Engine Control Units (ECU)
• Monitor gauges and map tracing on your ECU
• Data log from your ECU using consult, wideband and auxiliary inputs
• Perform playback using graphs, gauges and map tracing
Our System Provides:
• Connectivity for up to two emulators simultaneously (Pocket Romulator and Moates Ostrich)
• Loads and Saves files in regular and odd/even formats for chip burning (EPROM/FLASH)
Features:
• Real time tuning, map tracing, logging and
playback
• Full Log Recording for all NIStune ECUs
• Wideband can also be recorded inline with
consult data and played back.
• Map and table copy feature
• Completely editable multi window grid,
map/table views
• Resize injectors and change AFM
capabilities
• AFR and auxillary input trace against RPM
and load
• Consult display capabilities with real time
diagnostic information in separate windows
• Dual channel Wide Band support
• Edit five ROM images simulatenously, with
comparison capabilities
• Intelligent display tables decoded for easy
modification
• Real time RAM monitoring system
• Hardware and software installation guides
and manuals provided
What does this mean for a vehicle owner?
You can fit a real-time daughter board to your factory ECU and turn it into a fully remappable ECU, which makes it tuneable similar to aftermarket systems for a fraction of the price. This allows you to fit larger injectors, larger Mass Airflow Meters and get your ECU tuned for these and fuel and ignition changes. You can either tune it yourself or have it professionally tuned by one of our listed workshops.
Our NIStune Type 3 boards cover the following earlier consult vehicles:
• S13 180SX (SR20DET)
• S13 Silvia (SR20DE,DET)
• S13 240SX (KA24DE)
• U13 Bluebird (SR20DET)
• B13 Sentra/NX2000 (SR20DE)
• P10 Primera (SR20DE)
• J30 Maxima (VE30DE)
• S14 Silvia (SR20DET) [early model]
• N14/N15 Pulsar (SR18DE, SR20DE)
• RNN14 Pulsar (SR20DET)
Nistune uses a daughterboard for realtime tuning using a modified version of Nissan Consult. It provides faster transfer rates, realtime modification of maps, constants and tables using the NIStune software.
Provided with 40 pin header adaptor connector and instructions
Note: You will require consult cable to connect the laptop to your vehicle. Additionally tax, shipping and transaction fees may apply.
Bump to any interested party's
Type 3 Nistune Setup (In ECU) - R2500
Re: Type 3 Nistune Setup (In ECU) - R2500
Tentatively Sold, Awaiting Payment
